Model Driven Engineering for implementing the ISO 19100 series of international standards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2007
In this paper we discuss the implementation of the ISO 19100 series of standards with use of Model-Driven Engineering (MDE) techniques. We expose how MDE is beneficial for prototyping and building an end-user application dedicated to the sharing of environmental data (especially within the context of coastal zones). We present with an illustrating example of a way to use ISO 19109, 19110 and 19117 models in order to generate a rich client application. Our work takes the geographic features, the data structures and the data display concerns into account, by means of using the various facets of the ISO 19100 series.
Faucher07a.pdf (111.35 Ko) Télécharger le fichier
inria-00477571 , version 1 (29-04-2010)
  • HAL Id : inria-00477571 , version 1
Cyril Faucher, Jean-Yves Lafaye. Model Driven Engineering for implementing the ISO 19100 series of international standards. 2007. ⟨inria-00477571⟩
308 Consultations
128 Téléchargements
