Construction et maintien d'une forêt couvrante dans un réseau dynamique
In this work we introduce the principles of an algorithm that constructs and maintains a spanning forest in a mobile telecommunication network—a MANET. The algorithm is based on the random walk of a token and is entirely decentralized. A probability analysis is performed when the network is static. Then we show that performances can be slightly enhanced when adding a memory process in the walk on the token.
