ISO-TimeML: An International Standard for Semantic Annotation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present ISO-TimeML, a revised and interoperable version of the temporal markup language, TimeML. We describe the changes and enrichments made, while framing the effort in a more general methodology of semantic annotation. In particular, we assume a principled distinction between the annotation of an expression and the representation which that annotation denotes. This involves not only the specification of an annotation language for a particular phenomenon, but also the development of a meta-model that allows one to interpret the syntactic expressions of the specification semantically.
LREC-Final.pdf (63.68 Ko) Télécharger le fichier
inria-00479847 , version 1 (03-05-2010)
  • HAL Id : inria-00479847 , version 1
Pustejovsky James, Kiyong Lee, Harry Bunt, Laurent Romary. ISO-TimeML: An International Standard for Semantic Annotation. LREC 2010, May 2010, La Valette, Malta. ⟨inria-00479847⟩
Collections
INRIA INRIA2
242 Consultations
512 Téléchargements
