An algebraic approach for maximum friction estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new approach to estimate the road maximum adherence is presented. It is based on a combination of new algebraic tools for estimation and diagnosis via numerical differentiation of noisy signals. Instantaneous friction is first computed within this framework. Then, extended braking stiffness concept is exploited to detect which braking efforts allow to distinguish a road type from another. A weighted Dugoff model is used during these "distinguishable" intervals to estimate the maximum friction coefficient. Promising results have been obtained in noisy simulations and real experimentations.
NOLCOS_2010.pdf (345.77 Ko) Télécharger le fichier
inria-00484781 , version 1 (19-05-2010)
  • HAL Id : inria-00484781 , version 1
Jorge Villagra, Brigitte d'Andréa-Novel, Michel Fliess, Hugues Mounier. An algebraic approach for maximum friction estimation. 8th IFAC Symposium on Nonlinear Control Systems (NOLCOS), IFAC, Sep 2010, Bologna, Italy. ⟨inria-00484781⟩
677 Consultations
464 Téléchargements
