Exploring and Optimizing Dynamic Neural Fields Parameters Using Genetic Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jean-Charles Quinton
The Continuous Neural Field Theory introduces biologically-inspired competition mechanisms in computational models of perception and action. This paper deals with the use of Genetic Algorithms to optimize its parameters, as to guarantee the emergence of robust cognitive properties. Such properties include the tracking of initially salient stimuli despite strong noise and distracters. Interactions between the parameter values, input dynamics and accuracy of model, as well as their implications for Genetic Algorithms are discussed. The fitness function and set of scenarios used to evaluate the parameters through simulation must be carefully chosen. Experimental results reflect an ineluctable tradeoff between generality and performance.
Informatique
ag_cnft_IEEE_Xplore_compatible_PID1281655.pdf (506.33 Ko) Télécharger le fichier
inria-00488914 , version 1 (03-06-2010)
  • HAL Id : inria-00488914 , version 1
Jean-Charles Quinton. Exploring and Optimizing Dynamic Neural Fields Parameters Using Genetic Algorithms. IEEE World Congress on Computational Intelligence 2010 - WCCI 2010, Jul 2010, Barcelona, Spain. ⟨inria-00488914⟩
94 Consultations
178 Téléchargements
