Queries on XML Streams with Bounded Delay and Concurrency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 2011
Query answering algorithms on XML streams check answer candidates on the fly in order to avoid the unnecessary buffering whenever possible. The delay and concurrency of a query are two measures for the degree of their streamability. They count the maximal number of stream elements during the life time for some query answer, and respectively, the maximal number of simultaneously alive answer candidates of a query. We study queries defined by deterministic nested word automata, which subsume large streamable fragments of XPath subject to schema restrictions by DTDs modulo P-time translations. We show that bounded and k-bounded delay and concurrency of such automata-defined queries are all decidable in polynomial time in the size of the automaton. Our results are obtained by P-time reduction to the bounded valuedness problem for recognizable relations between unranked trees, a problem that we show to be decidable in P-time. This is a long version of a paper presented a LATA'09.
0.pdf (516.96 Ko) Télécharger le fichier
inria-00491495 , version 1 (06-09-2010)
Olivier Gauwin, Joachim Niehren, Sophie Tison. Queries on XML Streams with Bounded Delay and Concurrency. Information and Computation, 2011, Special Issue: 3rd International Conference on Language and Automata Theory and Applications (LATA 2009), 209 (3), pp.409-442. ⟨10.1016/j.ic.2010.08.003⟩. ⟨inria-00491495⟩
440 Consultations
220 Téléchargements
