SCORE: A Score-Based Memory Cache Replacement Policy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nam Duong
  • Fonction : Auteur
  • PersonId : 872207
Rosario Cammarota
  • Fonction : Auteur
  • PersonId : 872208
Dali Zhao
  • Fonction : Auteur
  • PersonId : 872209
Taesu Kim
  • Fonction : Auteur
  • PersonId : 872210
Alex Veidenbaum
  • Fonction : Auteur
  • PersonId : 872211
We propose SCORE, a novel adaptive cache replacement policy, which uses a score system to select a cache line to replace. Results show that SCORE o®ers low over-all miss rates on SPEC CPU2006 benchmarks, and provides an average IPC that is 4.9% higher than LRU and 7.4% higher than LIP.
004_duong.pdf (706.07 Ko) Télécharger le fichier
inria-00492956 , version 1 (17-06-2010)
  • HAL Id : inria-00492956 , version 1
Nam Duong, Rosario Cammarota, Dali Zhao, Taesu Kim, Alex Veidenbaum. SCORE: A Score-Based Memory Cache Replacement Policy. JWAC 2010 - 1st JILP Worshop on Computer Architecture Competitions: cache replacement Championship, Jun 2010, Saint Malo, France. ⟨inria-00492956⟩
Collections
ISCA2010 JWAC2010
220 Consultations
386 Téléchargements
