Supporting Application-Specific Speculation with Competitive Parallel Execution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parallel systems allow sequential programs that demand the highest possible performance or output quality to execute different versions of program parts in parallel to dynamically select the best version (i.e., the fastest or the one that produces the highest quality). The close coupling of multi-core systems offers new opportunities to explore such speculation. We discuss here how competitive parallel execution (CPE) supports such applicationspecific programmatic speculation. The key insight is that variations of the same program compete against each other during application-specific phases. These competing variants execute in complete isolation, thereby changing localized program state—comparable to a very coarse-grained transactional model. The state modifications of exactly one of these variants are committed and made globally visible based on an application-specific quality metric. The paper discusses operating system and architectural features to support and further extend the applicability and versatility of application-specific programmatic speculation. It also motivates the need for more research on how future systems can accommodate the diverse requirements of speculative approaches at different abstraction levels.
PESPMA-trachsel.pdf (433.53 Ko) Télécharger le fichier
inria-00494297 , version 1 (22-06-2010)
  • HAL Id : inria-00494297 , version 1
Oliver Trachsel, Thomas R. Gross. Supporting Application-Specific Speculation with Competitive Parallel Execution. Pespma 2010 - Workshop on Parallel Execution of Sequential Programs on Multi-core Architecture, Jun 2010, Saint Malo, France. ⟨inria-00494297⟩
64 Consultations
133 Téléchargements
