Can Realistic BitTorrent Experiments Be Performed on Clusters? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ashwin Rao
  • Fonction : Auteur
  • PersonId : 868330
Walid Dabbous
Network latency and packet loss are considered to be an important requirement for realistic evaluation of Peer-to-Peer protocols. Dedicated clusters, such as Grid'5000, do not provide the variety of network latency and packet loss rates that can be found in the Internet. However, compared to the experiments performed on testbeds such as PlanetLab, the experiments performed on dedicated clusters are reproducible, as the computational resources are not shared. In this paper, we perform experiments to study the impact of network latency and packet loss on the time required to download a file using BitTorrent. In our experiments, we observe a less than 15% increase on the time required to download a file when we increase the round-trip time between any two peers, from 0 ms to 400 ms, and the packet loss rate, from 0% to 5%. Our main conclusion is that the underlying network latency and packet loss have a marginal impact on the time required to download a file using BitTorrent. Hence, dedicated clusters such as Grid'5000 can be safely used to perform realistic and reproducible BitTorrent experiments.
BtExpClusters.pdf (247.84 Ko) Télécharger le fichier
inria-00494410 , version 1 (23-06-2010)
  • HAL Id : inria-00494410 , version 1
  • ARXIV : 1006.4490
Ashwin Rao, Arnaud Legout, Walid Dabbous. Can Realistic BitTorrent Experiments Be Performed on Clusters?. 10th IEEE International Conference on Peer-to-Peer Computing (IEEE P2P'10), Aug 2010, Delft, Netherlands. ⟨inria-00494410⟩
217 Consultations
271 Téléchargements
