From Synchronous Specifications to Statically-Scheduled Hard Real-Time Implementations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Hard real-time embedded systems are often designed as automatic control systems that can include both continuous and discrete parts. The functional specification of such systems is usually done in a conditioned data-flow formalism such as Simulink or Scade. These formalisms are either quasi-synchronous or synchronous, and they go beyond the classical data-flow model by introducing a form of conditional execution allowing the description of hierarchical execution modes. Specific real-time implementation approaches have been proposed for such formalisms, which exploit the hierarchical conditions to improve the generated code. We present one such approach which takes as input data-flow synchronous specifications and uses static scheduling heuristics to automatically produce efficient distributed real-time implementations. We explain how improving the analysis of the hierarchical conditions results in better implementations.
Fichier non déposé
inria-00495666 , version 1 (28-06-2010)
  • HAL Id : inria-00495666 , version 1
Dumitru Potop-Butucaru, Robert de Simone, Yves Sorel. From Synchronous Specifications to Statically-Scheduled Hard Real-Time Implementations. Sandeep K. Shukla and Jean-Pierre Talpin. Synthesis of Embedded Software: Frameworks and Methodologies for Correctness by Construction, Springer Science+Business Media, LLC 2010, pp.34, 2010, 978-1-4419-6399-4. ⟨inria-00495666⟩
110 Consultations
0 Téléchargements
