inria-00496120, version 2
FUSION OF MOTION SEGMENTATION WITH ONLINE ADAPTIVE NEURAL CLASSIFIER FOR ROBUST TRACKING
Slawomir Bak
1Sundaram Suresh 2François Bremond
2Monique Thonnat
2
Int. Joint Conf. on Computer Vision, Imaging and Computer Graphics Theory and Applications (VISAPP) (2009)
Résumé : This paper presents a method to fuse the information from motion segmentation with online adaptive neural classifier for robust object tracking. The motion segmentation with object classification identify new objects present in the video sequence. This information is used to initialize the online adaptive neural classifier which is learned to differentiate the object from its local background. The neural classifier can adapt to illumination variations and changes in appearance. Initialized objects are tracked in following frames using the fusion of their neural classifiers with the feedback from the motion segmentation. Fusion is used to avoid drifting problems due to similar appearance in the local background region. We demonstrate the approach in several experiments using benchmark video sequences with different level of complexity.
- 1 : Institute of Computer Science (ICS-UT-POZNAN)
- Poznan University of Technology
- 2 : PULSAR (INRIA Sophia Antipolis)
- INRIA
- Domaine : Sciences cognitives/Informatique
- Versions disponibles : v1 (30-06-2010) v2 (16-07-2010)
- inria-00496120, version 2
- http://hal.inria.fr/inria-00496120
- oai:hal.inria.fr:inria-00496120
- Contributeur : Slawomir Bak
- Soumis le : Vendredi 16 Juillet 2010, 12:13:10
- Dernière modification le : Mercredi 15 Septembre 2010, 16:31:39
Documents associés
Exporter
