LFT/Hinf varying sampling control for Autonomous Underwater Vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the robust control of an Autonomous Underwater Vehicle (AUV) subject to communication constraints. The aim is the design of a gain-scheduled varying sampling controller using non periodic measurements from ultrasonic sensors. The contribution of this work lies in a new model formulation of varying sampling discrete-time systems using the Linear Fractional Transformation (LFT) representation. This allows to design, in the LFT context, an Hinf controller whose matrices are scheduled w.r.t the varying control interval. Moreover the proposed design ensures a performance adaptation when the sampling interval varies. This methodology is developed for AUV and emphasizes important improvements compared with an Hinf discrete-time control with fixed sampling.
Automatique
sssc_2010.pdf (414.89 Ko) Télécharger le fichier
inria-00497049 , version 1 (02-07-2010)
  • HAL Id : inria-00497049 , version 1
Emilie Roche, Olivier Sename, Daniel Simon. LFT/Hinf varying sampling control for Autonomous Underwater Vehicles. SSSC 2010 - 4th IFAC Symposium on System, Structure and Control, IFAC, Sep 2010, Ancona, Italy. ⟨inria-00497049⟩
234 Consultations
379 Téléchargements
