Evaluating the capacity gains from Coordinated MultiPoint Transmission and Reception - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anais Vergne
This paper evaluates and compares different Coordinated MultiPoint (CoMP) Joint Processing (JP) schemes. We consider the LTE-Advanced codebook-based schemes, where the serving beams are taken from a pre-determined codebook. We namely consider Single User Joint Processing (SUJP) and Multiple Users Joint Processing (MUJP) with two variants: Least Interfering Beams (MUJPLIB) andMost Interfering Beams (MUJPMIB). We follow a cross-layer approach where both PHY and MAC layers mechanisms are taken into account by a realistic system-level simulator, whereas the higher level performance is assessed by a Markovian analysis. This latter considers the coupling between the different cells and derives the flow level capacities of the different solutions. Our results show that, globally, MUJP achieves the best performance for low to medium traffic, while all JP schemes do not perform well for large loads.
p401-vergne.pdf (382.91 Ko) Télécharger le fichier
inria-00499425 , version 1 (09-07-2010)
  • HAL Id : inria-00499425 , version 1
Anais Vergne, Salah Eddine Elayoubi. Evaluating the capacity gains from Coordinated MultiPoint Transmission and Reception. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.401-407. ⟨inria-00499425⟩
Collections
WIOPT2010
163 Consultations
102 Téléchargements
