Optimizing ARQ Strategies in Relay Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper the novel issue of retransmissions allocation in ARQ relay networks is introduced. In ARQ relay networks, the source and relays repeat a signal in response to a request from the destination. The source and relays can repeat once or multiple times with a constant power. Contrary to the protocols where a node is constrained to transmit once, we allow each node to retransmit multiple times. The goal is to allocate the optimal (minimum) number of retransmissions resulting in successful decoding at the destination. We devise an optimization method which is optimal. Moreover, the performance of the protocol with multiple retransmissions is compared to that of protocols with one retransmission per node or all the retransmissions from a single node. The results reveal that multiple retransmission protocols deliver superior performance over the counterparts.
p393-khan.pdf (392.07 Ko) Télécharger le fichier
inria-00499431 , version 1 (09-07-2010)
  • HAL Id : inria-00499431 , version 1
Aimal Khan, Volker Kuehn. Optimizing ARQ Strategies in Relay Networks. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.393-400. ⟨inria-00499431⟩
Collections
WIOPT2010
55 Consultations
110 Téléchargements
