inria-00499629, version 1
A Learning Approach for Adaptive Image Segmentation
Vincent Martin
1Nicolas Maillot a, 1Monique Thonnat
1
International Conference on Computer Vision Systems (2006) 40
Résumé : As mentioned in many papers, a lot of key parameters of image segmentation algorithms are manually tuned by designers. This induces a lack of flexibility of the segmentation step in many vision systems. By a dynamic control of these parameters, results of this crucial step could be drastically improved. We propose a scheme to automatically select segmentation algorithm and tune theirs key parameters thanks to a preliminary supervised learning stage. This paper details this learning approach which is composed by three steps: (1) optimal parameters extraction, (2) algorithm selection learning, and (3) generalization of parametrization learning. The major contribution is twofold: segmentation is adapted to the image to segment, and in the same time, this scheme can be used as a generic framework, independant of any application domain.
- a – INRIA
- 1 : ORION (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Vision par ordinateur et reconnaissance de formes
- Mots-clés : design methods for vision systems – image segmentation – learning techniques
- inria-00499629, version 1
- http://hal.inria.fr/inria-00499629
- oai:hal.inria.fr:inria-00499629
- Contributeur : Vincent Martin
- Soumis le : Dimanche 11 Juillet 2010, 13:09:30
- Dernière modification le : Lundi 19 Juillet 2010, 16:31:57
Documents associés
Exporter
