Using Model Driven Engineering technologies for building authoring applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Building authoring applications is a tedious and complex task that requires a high programming effort. Document technologies, especially XML based ones, can help in reducing such an effort by providing common bases for manipulating documents. Still, the overall task consists mainly of writing the application's source code. Model Driven Engineering (MDE) focuses on generating the source code from an exhaustive model of the application. In this paper, we illustrate that MDE technologies can be used to automate the development of authoring application components, but fail in generating the code of graphical components. We present our framework, called Malai, that aims to solve this issue.
Beaudoux10c.pdf (232.39 Ko) Télécharger le fichier
inria-00504672 , version 1 (21-07-2010)
  • HAL Id : inria-00504672 , version 1
Olivier Beaudoux, Arnaud Blouin, Jean-Marc Jézéquel. Using Model Driven Engineering technologies for building authoring applications. DocEng'10: Proceedings of the 2010 ACM symposium on Document engineering, 2010, Manchester, England, United Kingdom. ⟨inria-00504672⟩
218 Consultations
165 Téléchargements
