Challenging the Security of Content Based Image Retrieval Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thanh-Toan Do
  • Fonction : Auteur
  • PersonId : 870909
Ewa Kijak
Laurent Amsaleg
Content-Based Image Retrieval (CBIR) has been recently used as a filtering mechanism against the piracy of multimedia contents. Many publications in the last few years have proposed very robust schemes where pirated contents are detected despite severe modifications. As none of these systems have addressed the piracy problem from a security perspective, it is time to check whether they are secure: Can pirates mount violent attacks against CBIR systems by carefully studying the technology they use? This position paper is an initial analysis of the security flaws of the typical technology blocks used in state-of-the-art CBIR systems. It is so far too early to draw any definitive conclusion about their inherent security, but it motivates and encourages further studies on this topic.
main.pdf (524.78 Ko) Télécharger le fichier
inria-00505846 , version 1 (29-03-2011)
Thanh-Toan Do, Ewa Kijak, Teddy Furon, Laurent Amsaleg. Challenging the Security of Content Based Image Retrieval Systems. MMSP - EEE International Workshop on Multimedia Signal Processing, Oct 2010, Saint-Malo, France. ⟨10.1109/MMSP.2010.5661993⟩. ⟨inria-00505846⟩
246 Consultations
188 Téléchargements
