s'authentifier
version française rss feed
inria-00507020, version 1
An Approach to Seismic Interpretation Based on Cognitive Vision. The horizon Identification as an Application for the Cognitive Vision
Philippe Verney 1, Michel Perrin 2, Monique Thonnat () 3, Jean-Francois Rainaud a1
70th EAGE Conference and Exhibition (2008)
Résumé : Advanced seismic interpretation most commonly rests on transforming original data representations by considering more or less numerous seismic attributes, which bear no explicit relation with geology. For this reason, they hardly allow fully solving problems such as reassembling sparse geological surface elements or specifying chronological or topological relationships between surfaces such as unconformity, on lap, interruption by fault. The present work intends to make further progress in geology-based interpretation of seismic data by using artificial intelligence tools based on cognitive vision. We propose a cognitive vision workflow for seismic interpretation based on a visual ontology and on three associated module dealing for data management, visual characterisation and geological correlation. An example of results is given showing the possibilities of the method for easily merging disconnected reflectors within one stratigraphical horizon taking into account simple geological criteria (amplitude, thickness, dip, vertical distance between reflectors).
  • Domaine : Informatique/Vision par ordinateur et reconnaissance de formes
    Physique/Physique/Géophysique
    Planète et Univers/Sciences de la Terre/Géophysique
    Sciences de l'environnement/Milieux et Changements globaux
    Informatique/Intelligence artificielle
  • inria-00507020, version 1
  • oai:hal.inria.fr:inria-00507020
  • Contributeur :
  • Soumis le : Lundi 6 Septembre 2010, 11:29:30
  • Dernière modification le : Lundi 6 Septembre 2010, 13:07:06
tous les articles de la base du CCSd...
