s'authentifier
version française rss feed
inria-00509482, version 1
Bounds on the minimum distance of the duals of BCH codes
Daniel Augot () 1, Françoise Levy-Dit-Vehel a1
1994 IEEE International Symposium on Information Theory (1994) 43
Résumé : We consider duals of BCH codes of length p^m-1 over GF(p). A lower bound on their minimum distance is found via the adaptation of the Weil bound to cyclic codes. However, this bound is of no significance for roughly half of these codes. We partially fill this gap by giving a lower bound for an infinite class of duals of BCH codes. We also present a lower bound obtained with an algorithm due to Massey and Schaub (1988). In the case of binary codes of length 127 and 255, the results are surprisingly higher than all previously known bounds
  • Domaine : Informatique/Théorie de l'information et codage
    Mathématiques/Théorie de l'information et codage
  • inria-00509482, version 1
  • oai:hal.inria.fr:inria-00509482
  • Contributeur :
  • Soumis le : Mardi 30 Novembre 2010, 13:01:23
  • Dernière modification le : Mardi 30 Novembre 2010, 21:58:11
tous les articles de la base du CCSd...
