A Unified Hierarchical Algorithm for Global Illumination with Scattering Volumes and Object Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 1995
This paper presents a new radiosity algorithm that allows the simultaneous computation of energy exchanges between surface elements, scattering volume distributions, and groups of surfaces, or object clusters. The new technique is based on a hierarchical formulation of the zonal method, and efficiently integrates volumes and surfaces. In particular no initial linking stage is needed, even for inhomogeneous volumes, thanks to the construction of a global spatial hierarchy. An analogy between object clusters and scattering volumes results in a powerful clustering radiosity algorithm, with no initial linking between surfaces and fast computation of average visibility information through a cluster. We show that the accurate distribution of the energy emitted or received at the cluster level can produce even better results than isotropic clustering at a marginal cost. The resulting algorithm is fast and, more importantly, truly progressive as it allows the quick calculation of approximate solutions with a smooth convergence towards very accurate simulations.
main.pdf (7.43 Mo) Télécharger le fichier
cloud.mpg (90.5 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00509994 , version 1 (10-11-2010)
  • HAL Id : inria-00509994 , version 1
François X. Sillion. A Unified Hierarchical Algorithm for Global Illumination with Scattering Volumes and Object Clusters. IEEE Transactions on Visualization and Computer Graphics, 1995, 1 (3). ⟨inria-00509994⟩
98 Consultations
275 Téléchargements
