Modeling fractal shapes using generalizations of IFS techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
One of the major problems in geometric modeling is the control of shape construction. Indeed, one should be able to construct geometrical forms by combining or manipulating simple entities. This problem is even more important when we deal with fractal geometry. In this paper, we propose some methods for increasing the modeling capabilities of fractal shape constructions. We propose two extensions of the IFS model. The first is based on the integration of free form techniques in an IFS formalism, while the second deals with the definition of matrix of attractors to give a constructive approach of fractal shapes.
Mots clés
modeling_fractal.pdf (16.63 Mo) Télécharger le fichier
Format : Figure, Image
inria-00510101 , version 1 (01-12-2010)
  • HAL Id : inria-00510101 , version 1
Joëlle Thollot, Chems Eddine Zair, Eric Tosan, Denis Vandorpe. Modeling fractal shapes using generalizations of IFS techniques. Fractals in Engineering, May 1997, Arcachon, France. ⟨inria-00510101⟩
Collections
UNIV-LYON1 UDL
158 Consultations
236 Téléchargements
