Soft Shadow Volumes for Ray Tracing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2005
We present a new, fast algorithm for rendering physically-based soft shadows in ray tracing-based renderers. Our method replaces the hundreds of shadow rays commonly used in stochastic ray tracers with a single shadow ray and a local reconstruction of the visibility function. Compared to tracing the shadow rays, our algorithm produces exactly the same image while executing one to two orders of magnitude faster in the test scenes used. Our first contribution is a two-stage method for quickly determining the silhouette edges that overlap an area light source, as seen from the point to be shaded. Secondly, we show that these partial silhouettes of occluders, along with a single shadow ray, are sufficient for reconstructing the visibility function between the point and the light source.
SoftShadowVolumesRT.pdf (9.29 Mo) Télécharger le fichier
Format : Figure, Image
inria-00510157 , version 1 (13-10-2010)
  • HAL Id : inria-00510157 , version 1
Samuli Laine, Timo Aila, Ulf Assarsson, Jaakko Lehtinen, Tomas Akenine-Möller. Soft Shadow Volumes for Ray Tracing. ACM Transactions on Graphics, 2005, 24 (3). ⟨inria-00510157⟩
410 Consultations
750 Téléchargements
