Graphics Gems Revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2004
We present an algorithm for rendering faceted colored gemstones in real time, using graphics hardware. Beyond the technical challenge of handling the complex behavior of light in such objects, a real time high quality rendering of gemstones has direct applications in the field of jewelry prototyping, which has now become a standard practice for replacing tedious (and less interactive) wax carving methods. Our solution is based on a number of controlled approximations of the physical phenomena involved when light enters a stone, which permit an implementation based on the most recent -- yet commonly available -- hardware features such as fragment programs, cube-mapping and floating-point rendering.
GraphicsGemsRevisited.letter.pdf (6.32 Mo) Télécharger le fichier
Graphics_Gems_Revisited.tar.ppt (27.68 Mo) Télécharger le fichier
video_WWW_DivX.avi (36.21 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510165 , version 1 (13-10-2010)
  • HAL Id : inria-00510165 , version 1
Stéphane Guy, Cyril Soler. Graphics Gems Revisited. ACM Transactions on Graphics, 2004. ⟨inria-00510165⟩
471 Consultations
1103 Téléchargements
