Rendering Geometry with Relief Textures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We propose to render geometry using an image based representation. Geometric information is encoded by a texture with depth and rendered by rasterizing the bounding box geometry. For each resulting fragment, a shader computes the intersection of the corresponding ray with the geometry using pre-computed information to accelerate the computation. Great care is taken to be artifact free even when zoomed in or at grazing angles. We integrate our algorithm with reverse perspective projection to represent a larger class of shapes. The extra texture requirement is small and the rendering cost is output sensitive so our representation can be used to model many parts of a 3D scene.
Mots clés
relief05.pdf (3.88 Mo) Télécharger le fichier
Relief05.avi (34.25 Mo) Télécharger le fichier
slides.ppt (4.23 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510228 , version 1 (13-10-2010)
  • HAL Id : inria-00510228 , version 1
Lionel Baboud, Xavier Décoret. Rendering Geometry with Relief Textures. Graphics Interface '06, 2006, Quebec, Canada. ⟨inria-00510228⟩
387 Consultations
627 Téléchargements
