BlobSeer: Next Generation Data Management for Large Scale Infrastructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2011
Gabriel Antoniu
Luc Bougé
Diana Moise
  • Fonction : Auteur
  • PersonId : 856286
As data volumes increase at a high speed in more and more application fields of science, engineering, information services, etc., the challenges posed by data-intensive computing gain an increasing importance. The emergence of highly scalable infrastructures, e.g. for cloud computing and for petascale computing and beyond introduces additional issues for which scalable data management becomes an immediate need. This paper brings several contributions. First, it proposes a set of principles for designing highly scalable distributed storage systems that are optimized for heavy data access concurrency. In particular, we highlight the potentially large benefits of using versioning in this context. Second, based on these principles, we propose a set of versioning algorithms, both for data and metadata, that enable a high throughput under concurrency. Finally, we implement and evaluate these algorithms in the BlobSeer prototype, that we integrate as a storage backend in the Hadoop MapReduce framework. We perform extensive microbenchmarks as well as experiments with real MapReduce applications: they demonstrate that applying the principles defended in our approach brings substantial benefits to data intensive applications.
paper.pdf (293.42 Ko) Télécharger le fichier
inria-00511414 , version 1 (24-08-2010)
Bogdan Nicolae, Gabriel Antoniu, Luc Bougé, Diana Moise, Alexandra Carpen-Amarie. BlobSeer: Next Generation Data Management for Large Scale Infrastructures. Journal of Parallel and Distributed Computing, 2011, 71 (2), pp.168-184. ⟨10.1016/j.jpdc.2010.08.004⟩. ⟨inria-00511414⟩
949 Consultations
932 Téléchargements
