3D and Appearance Modeling from Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper gives an overview of works done in our group on 3D and appearance modeling of objects, from images. The backbone of our approach is to use what we consider as the principled optimization criterion for this problem: to maximize photoconsistency between input images and images rendered from the estimated surface geometry and appearance. In initial works, we have derived a general solution for this, showing how to write the gradient for this cost function (a non-trivial undertaking). In subsequent works, we have applied this solution to various scenarios: recovery of textured or uniform Lambertian or non-Lambertian surfaces, under static or varying illumination and with static or varying viewpoint. Our approach can be applied to these different cases, which is possible since it naturally merges cues that are often considered separately: stereo information, shading, silhouettes. This merge naturally happens as a result of the cost function used: when rendering estimated geometry and appearance (given known lighting conditions), the resulting images automatically contain these cues and their comparison with the input images thus implicitly uses these cues simultaneously.
ciarp.pdf (772.93 Ko) Télécharger le fichier
Format : Figure, Image
inria-00511434 , version 1 (25-08-2010)
Peter Sturm, Amael Delaunoy, Pau Gargallo, Emmanuel Prados, Kuk-Jin Yoon. 3D and Appearance Modeling from Images. CIARP 2009 - 14th Iberoamerican Congress on Pattern Recognition, Nov 2009, Guadalajara, Mexico. pp.695-704, ⟨10.1007/978-3-642-10268-4_82⟩. ⟨inria-00511434⟩
716 Consultations
209 Téléchargements
