A geometric invariant shape descriptor based on the Radon, Fourier, and Mellin transforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new shape descriptor invariant to geometric transformation based on the Radon, Fourier, and Mellin transforms is proposed. The Radon transform converts the geometric transformation applied on a shape image into transformation in the columns and rows of the Radon image. Invariances to translation, rotation, and scaling are obtained by applying 1D Fourier-Mellin and Fourier transforms on the columns and rows of the shape's Radon image respectively. Experimental results on different datasets show the usefulness of the proposed shape descriptor.
ICPR2010.pdf (299.35 Ko) Télécharger le fichier
inria-00512312 , version 1 (13-09-2010)
Thai V. Hoang, Salvatore Tabbone. A geometric invariant shape descriptor based on the Radon, Fourier, and Mellin transforms. International Conference on Pattern Recognition - ICPR'2010, Aug 2010, Istanbul, Turkey. pp.2085-2088, ⟨10.1109/ICPR.2010.512⟩. ⟨inria-00512312⟩
621 Consultations
919 Téléchargements
