A general framework for subexponential discrete logarithm algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Arithmetica Année : 2002
We describe a generic algorithm for computing discrete logarithms in groups of known order in which a smoothness concept is available. The running time of the algorithm can be proved without using any heuristics and leads to a subexponential complexity in particular for finite fields and class groups of number and function fields which were proposed for use in cryptography. In class groups, our algorithm is substantially faster than previously suggested ones. The subexponential complexity is obtained for cyclic groups in which a certain smoothness assumption is satisfied. We also show how to modify the algorithm for cyclic subgroups of arbitrary groups when the smoothness assumption can only be verified for the full group.
acta.pdf (263.74 Ko) Télécharger le fichier
inria-00512717 , version 1 (31-08-2010)
Andreas Enge, Pierrick Gaudry. A general framework for subexponential discrete logarithm algorithms. Acta Arithmetica, 2002, 102, pp.83-103. ⟨10.4064/aa102-1-6⟩. ⟨inria-00512717⟩
423 Consultations
516 Téléchargements
