An extension of Satoh's algorithm and its implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Ramanujan Mathematical Society Année : 2000
We describe a fast algorithm for counting points on elliptic curves defined over finite fields of small characteristic, following Satoh. Our main contribution is an extension to characteristics two and three. We give a detailed description with the optimisations necessary for an efficient implementation. Finally we give the number of points we have computed on a ``random'' curve defined over the field Fq with q=2^8009.
satoh.pdf (336.4 Ko) Télécharger le fichier
inria-00512791 , version 1 (31-08-2010)
  • HAL Id : inria-00512791 , version 1
Mireille Fouquet, Pierrick Gaudry, Robert Harley. An extension of Satoh's algorithm and its implementation. Journal of the Ramanujan Mathematical Society, 2000, 15, pp.281-318. ⟨inria-00512791⟩
278 Consultations
265 Téléchargements
