From Safety Verification to Safety Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
A methodology that combines verification and conformance testing for validating safety requirements of reactive systems is presented. The requirements are first automatically verifed on the systems specification. Then test cases are automatically derived from the specification and the requirements and executed on a blackbox implementation of the system. The test cases attempt to push the implementation into violating a requirement. We show that an implementation conforms to its specification if and only if it passes all the test cases generated in this way Keywords verification conformance testing safety properties
2004-TESTCOM.pdf (299.78 Ko) Télécharger le fichier
inria-00517304 , version 1 (14-09-2010)
Vlad Rusu, Hervé Marchand, Valérie Tschaen, Thierry Jéron, Bertrand Jeannet. From Safety Verification to Safety Testing. Testing of Communicating Systems (Testcom), Mar 2004, Oxford, United Kingdom. pp.160-176, ⟨10.1007/978-3-540-24704-3_11⟩. ⟨inria-00517304⟩
52 Consultations
70 Téléchargements
