Visual Simulation of Multiple Unmixable Fluids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer Science and Technology Année : 2007
We present a novel grid-based method for simulating multiple unmixable fluids moving and interacting. Unlike previous methods that can only represent the interface between two fluids (usually between liquid and gas), this method can handle an arbitrary number of fluids through multiple independent level sets coupled with a constrain condition. To capture the fluid surface more accurately, we extend the particle level set method to a multi-fluid version. It shares the advantages of the particle level set method, and has the ability to track the interfaces of multiple fluids. To handle the dynamic behavior of different fluids existing together, we use a multiphase fluid formulation based on a smooth weight function.
WenZheng2007a.pdf (696.73 Ko) Télécharger le fichier
inria-00517962 , version 1 (16-09-2010)
Wen Zheng, Jun-Hai Yong, Jean-Claude Paul. Visual Simulation of Multiple Unmixable Fluids. Journal of Computer Science and Technology, 2007, 22 (1), pp.156-160. ⟨10.1007/s11390-007-9021-y⟩. ⟨inria-00517962⟩
174 Consultations
243 Téléchargements
