Atlas-Based Reduced Models of Blood Flows for Fast Patient-Specific Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Model-based interpretation of the complex clinical data now available (shape, motion, flow) can provide quantitative information for diagnosis as well as predictions. However such models can be extremely time consuming, which does not always fit with the clinical time constraints. The aim of this work is to propose a model reduction technique to perform faster patient-specific simulations with prior knowledge built from simulations on an average anatomy. Rather than simulating a full fluid problem on individual patients, we create a representative `template' of the artery shape. A full flow simulation is carried out only on this template, and a reduced model is built from the results. Then this reduced model can be transported to the individual geometries, allowing faster computational analysis. % Here we propose a preliminary validation of this idea. A well-posed framework based on currents representation of shapes is used to create an unbiased template of the pulmonary artery for 4 patients with Tetralogy of Fallot. Then, a reduced computational fluid dynamics model is built on this template. Finally, we demonstrate that this reduced model can represent a specific patient simulation.
2010_miccai_lncs.pdf (563.17 Ko) Télécharger le fichier
inria-00517994 , version 1 (16-09-2010)
Paternité
Kristin Mcleod, Alfonso Caiazzo, Miguel Angel Fernández, Tommaso Mansi, Irene Vignon-Clementel, et al.. Atlas-Based Reduced Models of Blood Flows for Fast Patient-Specific Simulations. STACOM 2010 - Statistical Atlases and Computational Modeling of the Heart, Sep 2010, Beijing, China. pp.95-104, ⟨10.1007/978-3-642-15835-3_10⟩. ⟨inria-00517994⟩
484 Consultations
267 Téléchargements
