Improving Random Walk Estimation Accuracy with Uniform Restarts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
This work proposes and studies the properties of a hybrid sampling scheme that mixes independent uniform node sampling and random walk (RW)-based crawling. We show that our sampling method combines the strengths of both uniform and RW sampling while minimizing their drawbacks. In particular, our method increases the spectral gap of the random walk, and hence, accelerates convergence to the stationary distribution. The proposed method resembles PageRank but unlike PageRank preserves time-reversibility. Applying our hybrid RW to the problem of estimating degree distributions of graphs shows promising results.
RR-7394.pdf (695.09 Ko) Télécharger le fichier
inria-00520350 , version 1 (23-09-2010)
  • HAL Id : inria-00520350 , version 1
Konstantin Avrachenkov, Bruno Ribeiro, Don Towsley. Improving Random Walk Estimation Accuracy with Uniform Restarts. [Research Report] RR-7394, INRIA. 2010. ⟨inria-00520350⟩
116 Consultations
865 Téléchargements
