Foundation of a Component-based Flexible Registry for Language Resources and Technolog
Within the CLARIN e-science infrastructure project it is foreseen to develop a component-based registry for metadata for Language Resources and Language Technology. With this registry it is hoped to overcome the problems of the current available systems with respect to inflexible fixed schema, unsuitable terminology and interoperability problems. The registry will address interoperability needs by refering to a shared vocabulary registered in data category registries as they are suggested by ISO.
Informatique et langage [cs.CL]
