A CSP Approach to Control in Event-B - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Event-B has emerged as one of the dominant state-based formal techniques used for modelling control-intensive applications. Due to the blocking semantics of events, their ordering is controlled by their guards. In this paper we explore how process algebra descriptions can be defined alongside an Event-B model. We will use CSP to provide explicit control flow for an Event-B model and alternatively to provide a way of separating out requirements which are dependent on control flow information. We propose and verify new conditions on combined specifications which establish deadlock freedom. We discuss how combined specifications can be refined and the challenges arising from this. The paper uses Abrial's Bridge example as the basis of a runningexample to illustrate the framework.
schneiderIFM2010-long260.pdf (247.63 Ko) Télécharger le fichier
inria-00524603 , version 1 (08-10-2010)
  • HAL Id : inria-00524603 , version 1
Steve Schneider, Helen Treharne, Heike Wehrheim. A CSP Approach to Control in Event-B. Integrated Formal Methods - IFM 2010, INRIA Nancy Grand Est, Oct 2010, Nancy, France. pp.260-274. ⟨inria-00524603⟩
56 Consultations
424 Téléchargements
