Strong generative capacity of RST, SDRT and discourse dependency DAGSs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
The aim of this paper is to compare the discourse structures proposed in RST, SDRT and dependency DAGs which extend the semantic level of MTT for discourses. The key question is the following: do these formalisms allow the representation of all the discourse structures which correspond to felicitous discourses and exclude those which correspond to infelicitous discourses? Hence the term of “strong generative capacity” taken from formal grammars.
Dortmund_05-book-bis.pdf (486.94 Ko) Télécharger le fichier
inria-00524739 , version 1 (08-10-2010)
  • HAL Id : inria-00524739 , version 1
Laurence Danlos. Strong generative capacity of RST, SDRT and discourse dependency DAGSs. A. Benz and P. Kuhnlein. Constraints in Discourse, Benjamins, pp.69--95, 2008. ⟨inria-00524739⟩
125 Consultations
457 Téléchargements
