CES/XML : An XML-based Standard for Linguistic Corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The Corpus Encoding Standard (CES) is a part of the EAGLES Guidelines developed by the Expert Advisory Group on Language Engineering Standards (EAGLES) that provides a set of encoding standards for corpus-based work in natural language processing applications. We have instantiated the CES as an XML application called XCES, based on the same data architecture comprised of a primary encoded text and "standoff" annotation in separate documents. Conversion to XML enables use of some of the more powerful mechanisms provided in the XML framework, including the XSLT Transformation Language, XML Schemas, and support for inter-rescue reference together with an extensive path syntax for pointers. In this paper, we describe the differences between the CES and XCES DTDs and demonstrate how XML mechanisms can be used to select from and manipulate annotated corpora encoded according to XCES specifications. We also provide a general overview of XML and the XML mechanisms that are most relevant to language engineering research and applications.
xces.lrec00.pdf (38.41 Ko) Télécharger le fichier
inria-00525250 , version 1 (12-10-2010)
  • HAL Id : inria-00525250 , version 1
Nancy Ide, Patrice Bonhomme, Laurent Romary. CES/XML : An XML-based Standard for Linguistic Corpora. LREC Conference, May 2000, Athens, Greece. ⟨inria-00525250⟩
237 Consultations
380 Téléchargements
