A Method for 3D Reconstruction of Piecewise Planar Objects from Single Panoramic Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We present an approach for 3D reconstruction of objects from a single panoramic image. Obviously, constraints on the 3D structure are needed to perform this task. Our approach is based on user-provided coplanarity, perpendicularity and parallelism constraints. The method is described in detail for the case of a parabolic mirror-based omnidirectional sensor and results are provided.
Sturm-omni00.pdf (569.75 Ko) Télécharger le fichier
inria-00525670 , version 1 (30-05-2011)
Peter Sturm. A Method for 3D Reconstruction of Piecewise Planar Objects from Single Panoramic Images. IEEE Workshop on Omnidirectional Vision (OMNVIS '00), Jun 2000, Hilton Head Island, United States. pp.119-126, ⟨10.1109/OMNVIS.2000.853818⟩. ⟨inria-00525670⟩
289 Consultations
469 Téléchargements
