Self-Calibration of a Moving Zoom-Lens Camera by Pre-Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Image and Vision Computing Année : 1997
We consider the problem of self-calibrating a moving camera which is equipped with a zoom lens. This consists essentially in estimating the 5 intrinsic parameters of the pinhole camera model. However, these parameters are not independent. Thus, we propose to do a pre-calibration of the camera, with the aim to model the interdependence of the intrinsic parameters. We show that self-calibration then comes down to the estimation of only 1 intrinsic parameter. We propose a method which exploits this and which does not need an initialization of the intrinsic parameters. The method consists mainly in finding the closest common root of several low-degree polynomials. Besides the simple computations needed, it is easy to parallelize and thus well suited for future real-time application. The improvement of our method on self-calibration without pre-calibration is shown by experiment.
inria-00525691 , version 1 (12-10-2010)
Peter Sturm. Self-Calibration of a Moving Zoom-Lens Camera by Pre-Calibration. Image and Vision Computing, 1997, 15 (8), pp.583-589. ⟨10.1016/S0262-8856(97)00015-2⟩. ⟨inria-00525691⟩
110 Consultations
0 Téléchargements
