s'authentifier
version française rss feed
inria-00527150, version 1
Single Node On-Line Simulation of MPI Applications with SMPI
Pierre-Nicolas Clauss () 1, Mark Stillwell a2, Stéphane Genaud () 13, Frédéric Suter () b4, Henri Casanova () 2, Martin Quinson () c1
International Parallel & Distributed Processing Symposium (2011)
Résumé : Simulation is a popular approach for predicting the performance of MPI applications for platforms that are not at one's disposal. It is also a way to teach the principles of parallel programming and high-performance computing to students without access to a parallel computer. In this work we present SMPI, a simulator for MPI applications that uses on-line simulation, i.e., the application is executed but part of the execution takes place within a simulation component. SMPI simulations account for network contention in a fast and scalable manner. SMPI also implements an original and validated piece-wise linear model for data transfer times between cluster nodes. Finally SMPI simulations of large-scale applications on large-scale platforms can be executed on a single node thanks to techniques to reduce the simulation's compute time and memory footprint. These contributions are validated via a large set of experiments in which SMPI is compared to popular MPI implementations with a view to assess its accuracy, scalability, and speed.
  • Collaboration : Grid'5000
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • Mots-clés : Message Passing Interace – On-line Simulation – Performance Prediction
  • Référence interne : RR-7426
  • inria-00527150, version 1
  • oai:hal.inria.fr:inria-00527150
  • Contributeur :
  • Soumis le : Lundi 18 Octobre 2010, 12:55:01
  • Dernière modification le : Jeudi 6 Septembre 2012, 17:30:04
tous les articles de la base du CCSd...
