Finding an induced subdivision of a digraph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We consider the following problem for oriented graphs and digraphs: Given an oriented graph (digraph) $G$, does it contain an induced subdivision of a prescribed digraph $D$? The complexity of this problem depends on $D$ and on whether $H$ must be an oriented graph or is allowed to contain 2-cycles. We give a number of examples of polynomial instances as well as several NP-completeness proofs
RR-7430.pdf (255.04 Ko) Télécharger le fichier
inria-00527518 , version 1 (19-10-2010)
  • HAL Id : inria-00527518 , version 1
Jørgen Bang-Jensen, Frédéric Havet, Nicolas Trotignon. Finding an induced subdivision of a digraph. [Research Report] RR-7430, INRIA. 2010. ⟨inria-00527518⟩
210 Consultations
298 Téléchargements
