inria-00528487, version 1
Accelerating a 3D finite-difference wave propagation code using GPU graphics cards
David Michéa 1Dimitri Komatitsch 2
Geophys. J. Int. 182, 1 (2010) 389-402
Résumé : We accelerate a three-dimensional finite-difference in the time domain (FDTD) wave propagation code by a factor between about 20 and 60 compared to a serial implementation using Graphics Processing Unit (GPU) computing on NVIDIA graphics cards with the CUDA programming language. We describe the implementation of the code in CUDA to simulate the propagation of seismic waves in a heterogeneous elastic medium. We also implement Convolution Perfectly Matched Layers (CPMLs) on the graphics cards to efficiently absorb outgoing waves on the fictitious edges of the grid. We show that the code that runs on a graphics card gives the expected results by comparing our results to those obtained by running the same simulation on a classical processor core. The methodology that we present can be used for Maxwell's equations as well because their form is similar to that of the seismic wave equation written in velocity vector and stress tensor.
- 1 : Bureau de recherches géologiques et minières (BRGM)
- BRGM
- 2 : MAGIQUE-3D (INRIA Bordeaux - Sud-Ouest)
- INRIA – CNRS – Université de Pau et des Pays de l'Adour
- Domaine : Informatique/Calcul parallèle, distribué et partagé
- inria-00528487, version 1
- http://hal.inria.fr/inria-00528487
- oai:hal.inria.fr:inria-00528487
- Contributeur : Dimitri Komatitsch
- Soumis le : Mardi 30 Novembre 2010, 13:04:47
- Dernière modification le : Mardi 30 Novembre 2010, 21:58:55
Documents associés
Exporter
