s'authentifier
version française rss feed
inria-00529121, version 1
The Cost Optimal Solution of the Multi-Constrained Multicast Routing Problem
Miklós Molnár () 1, Alia Bellabas () a2, Samer Lahoud () a2
N° PI-1957 (2010)
Résumé : In this paper, we study the cost optimal solution of the well-known multi-constrained multicast routing problem. This problem consists in finding a multicast structure that spans a source node and a set of destination nodes with respect to a set of constraints. This optimization problem is particularly interesting for the multicast network communications that require Quality of Service (QoS) guarantees. Moreover, finding the multicast structure with respect to the defined QoS requirements while minimizing a cost function is an NP-difficult optimization problem. According to the state-of-the-art, to solve the multi-constrained multicast routing problem, most of the proposed algorithms search for a multicast tree. In this paper, we demonstrate that the optimal connected partial spanning structure that solves the multi-constrained multicast routing problem can be different from a partial spanning tree. Indeed, we show that the minimum cost solution always corresponds to hierarchy, a recently proposed simple generalization of the tree concept. For that, we define and analyze the partial minimum spanning hierarchies as optimal solutions for the multi-constrained multicast routing problem. Moreover, we propose a branch and cut type exact algorithm that is based on some relevant properties of the hierarchical solutions.
  • Domaine : Informatique/Autre
  • Mots-clés : Multicast – quality of service – multi-constrained Steiner problem – hierarchy – partial minimum spanning hierarchy
  • Référence interne : PI-1957
  • inria-00529121, version 1
  • oai:hal.inria.fr:inria-00529121
  • Contributeur :
  • Soumis le : Lundi 25 Octobre 2010, 09:12:23
  • Dernière modification le : Jeudi 7 Avril 2011, 17:11:42
tous les articles de la base du CCSd...
