Toeplitz-Structured Chaotic Sensing Matrix for Compressive Sensing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Compressive Sensing (CS) is a new sampling theory which allows signals to be sampled at sub-Nyquist rate without loss of information. Fundamentally, its procedure can be modeled as a linear projection on one specific sensing matrix, which, in order to guarantee the information conservation, satisfies Restricted Isometry Property (RIP). Ordinarily, this matrix is constructed by the Gaussian random matrix or Bernoulli random matrix. In previous work, we have proved that the typical chaotic sequence - logistic map can be adopted to generate the sensing matrix for CS. In this paper, we show that Toeplitz-structured matrix constructed by chaotic sequence is sufficient to satisfy RIP with high probability. With the Toeplitz-structured Chaotic Sensing Matrix (TsCSM), we can easily build a filter with small number of taps. Meanwhile, we implement the TsCSM in compressive sensing of images.
csndsp2010_camara.pdf (272.09 Ko) Télécharger le fichier
inria-00530050 , version 1 (29-10-2010)
  • HAL Id : inria-00530050 , version 1
Lei Yu, Jean-Pierre Barbot, Gang Zheng, Hong Sun. Toeplitz-Structured Chaotic Sensing Matrix for Compressive Sensing. IEEE, IET International Symposium on COMMUNICATION SYSTEMS, NETWORKS AND DIGITAL SIGNAL PROCESSING, Oct 2010, Newcastle, United Kingdom. ⟨inria-00530050⟩
280 Consultations
909 Téléchargements
