On Continued Fraction Expansion of Real Roots of Polynomial Systems, Complexity and Condition Numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2011
We elaborate on a correspondence between the coeffcients of a multivariate polynomial represented in the Bernstein basis and in a tensor-monomial basis, which leads to homography representations of polynomial functions, that use only integer arithmetic (in contrast to Bernstein basis) and are feasible over unbounded regions. Then, we study an algorithm to split this representation and we obtain a subdivision scheme for the domain of multivariate polynomial functions. This implies a new algorithm for real root isolation, MCF, that generalizes the Continued Fraction (CF) algorithm of univariate polynomials. A partial extension of Vincent's Theorem for multivariate polynomials is presented, which allows us to prove the termination of the algorithm. Bounding functions, projection and preconditioning are employed to speed up the scheme. The resulting isolation boxes have optimized rational coordinates, corresponding to the first terms of the continued fraction expansion of the real roots. Finally, we present new complexity bounds for a simplified version of the algorithm in the bit complexity model, and also bounds in the real RAM model for a family of subdivision algorithms in terms of the real condition number of the system. Examples computed with our C++ implementation illustrate the practical aspects of our method.
mcf_tcs.pdf (535.26 Ko) Télécharger le fichier
Format : Figure, Image
inria-00530756 , version 1 (29-10-2010)
Angelos Mantzaflaris, Bernard Mourrain, Elias Tsigaridas. On Continued Fraction Expansion of Real Roots of Polynomial Systems, Complexity and Condition Numbers. Theoretical Computer Science, 2011, 412 (22), pp.2312-2330. ⟨10.1016/j.tcs.2011.01.009⟩. ⟨inria-00530756⟩
315 Consultations
713 Téléchargements
