s'authentifier
version française rss feed
inria-00531636, version 1
Dr Geo II: Adding Interactivity Planes in Interactive Dynamic Geometry
Hilaire Fernandes 1, Stéphane Ducasse () 1, Thibault Carron 2
International Conference on Creating, Connecting and Collaborating through Computing (C5 2007) (2007)
Résumé : Interactive geometry environments support the creation and exploitation of interactive geometric sketches. However, such environments are often driven in a rigid manner, following a well specified construction path. This rigidity is not always compatible with: i. the internal cognitive representation of the learner about the geometric domain and ii. the way a geometric sketch is used in a paper-pen environment. This rigidity is therefore a source of internal tension for the learner and it can reduce the pedagogical added value of the interactive geometry environments. We think additional interactive planes to manipulate a geometric sketch differently can help the learner. We have developed DR. GEO II, an interactive geometry framework that is able to receive additional interactive planes such as a free sketching and a command-based one. We have experimented it in a junior high school class and we report here our first results.
  • Domaine : Informatique/Apprentissage
  • inria-00531636, version 1
  • oai:hal.inria.fr:inria-00531636
  • Contributeur :
  • Soumis le : Mercredi 3 Novembre 2010, 14:09:53
  • Dernière modification le : Jeudi 4 Novembre 2010, 12:01:54
tous les articles de la base du CCSd...
