Numerical and theoretical investigation of a simplified model for the parameterization of below-cloud scavenging by falling raindrops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Environment Année : 2002
The aim of this article is to propose an appropriate framework for investigating the validity of usual parameterizations of below-cloud scavenging by falling raindrops. We recall the underlying models and we study an adimensionalized form of the exact model in a simplified case (monodisperse raindrops and passive tracer) by defining some key parameters. We show that these parameters control the validity of the parameterization that we recover through asymptotic expansion. Some numerical tests for species HNO3 and SO2 illustrate these results.
inria-00532763 , version 1 (04-11-2010)
Bruno Sportisse, Laurent Du Bois. Numerical and theoretical investigation of a simplified model for the parameterization of below-cloud scavenging by falling raindrops. Atmospheric Environment, 2002, 36 (36-37), pp.5719-5727. ⟨10.1016/S1352-2310(02)00576-9⟩. ⟨inria-00532763⟩
99 Consultations
0 Téléchargements
