An algorithm for image representation as independent levels of resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Recently it has been shown that natural images possess a special type of scale invariant statistics (multiscaling). In this paper, we will show how the multiscaling properties of images can be used to derive a redundancy-reducing oriented wavelet basis. This kind of representation can be learnt from the data and is optimally adapted for image coding; besides, it shows some features found in the visual pathway
Turiel-ICANN-2002.pdf (328.19 Ko) Télécharger le fichier
inria-00532769 , version 1 (15-04-2016)
  • HAL Id : inria-00532769 , version 1
Antonio Turiel, Jean-Pierre Nadal, Nestor Parga. An algorithm for image representation as independent levels of resolution. Proceedings of the International Conference in Artificial Neural Networks (ICANN), 2002, Madrid, Spain. pp.1213-1218. ⟨inria-00532769⟩
138 Consultations
109 Téléchargements
