Model-Centric, Context-Aware Software Adaptation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
Oscar Nierstrasz
Marcus Denker
Lukas Renggli
  • Fonction : Auteur
  • PersonId : 881344
Software must be constantly adapted to changing requirements. The time scale, abstraction level and granularity of adaptations may vary from short-term, fine-grained adaptation to long-term, coarse-grained evolution. Fine-grained, dynamic and context-dependent adaptations can be particularly difficult to realize in long-lived, large-scale software systems. We argue that, in order to effectively and efficiently deploy such changes, adaptive applications must be built on an infrastructure that is not just model-driven, but is both model-centric and context-aware. Specifically, this means that high-level, causally-connected models of the application and the software infrastructure itself should be available at run-time, and that changes may need to be scoped to the run-time execution context. We first review the dimensions of software adaptation and evolution, and then we show how model-centric design can address the adaptation needs of a variety of applications that span these dimensions. We demonstrate through concrete examples how model-centric and context-aware designs work at the level of application interface, programming language and runtime. We then propose a research agenda for a model-centric development environment that supports dynamic software adaptation and evolution.
Nier09aModelCentric.pdf (177.22 Ko) Télécharger le fichier
inria-00532825 , version 1 (04-11-2010)
Oscar Nierstrasz, Marcus Denker, Lukas Renggli. Model-Centric, Context-Aware Software Adaptation.. Cheng, Betty and de Lemos, Rogério and Giese, Holger and Inverardi, Paola and Magee, Jeff. Software Engineering for Self-Adaptive Systems, 5525, Springer, pp.128-145, 2009, LNCS, 3642021603. ⟨10.1007/978-3-642-02161-9_7⟩. ⟨inria-00532825⟩
35 Consultations
325 Téléchargements
