Complexity Bounds for Batch Active Learning in Classification
Active learning is a branch of Machine Learning in which the learning algorithm, instead of being directly provided with pairs of problem instances and their solutions (their labels), is allowed to choose, from a set of unlabeled data, which instances to query. It is suited to settings where labeling instances is costly. This paper analyzes the speed-up of batch (parallel) active learning compared to sequential active learning (where instances are chosen 1 by 1): how faster can an algorithm become if it can query instances at once? There are two main contributions: proving lower and upper bounds on the possible gain, and illustrating them by experimenting on usual active learning algorithms. Roughly speaking, the speed-up is asymptotically logarithmic in the batch size (i.e. when ! 1). However, for some classes of functions with finite VC-dimension V , a linear speed-up can be achieved until a batch size of V . Practically speaking, this means that parallelizing computations on an expensive-to-label problem which is suited to active learning is very beneficial until V simultaneous queries, and less interesting (yet still bringing improvement) afterwards.
